Group curtain header stirrup
As far as I can see from the picture, it is normal that the headboards are not formed since the P610 and P611 frets are very short. You will intervene manually: double click on the curtains, in the window that opens, click on the "rebar tab". In this window, set the "header zone length" to be user-defined and define the headboard length as the length of the curtain. Define the left end for pitch P610 and the right end for pitch P611. The other ends will be zero. When you get a drawing, you need to delete the eryes (distribution) of the curtain bodies. If you don't want to deal with these, you define an L-shaped polygon column at the curtain end instead of the P610 and P611 curtains.
Hello Mr. MaFiAMaX, you must additionally solve the hollow structure as mixed. When such a solution is made: --Relative floor offsets, --Reinforcement, --overturning error according to item 4.3.4.6. Solution: Solve hollow blocks by turning them into square or nearly square cassettes. Ünver ÖZCAN
"unver":29r5max" said:
Hi Mr. MaFiAMaX, in addition to You should solve the hollow block structure as a composite When the solution is done like this: --Relative story drifts, --Reinforcement, --overturn according to item 4.3.4.6 Solution: Solve the hollow tiles by turning them into square or near-square cassettes. Ünver ÖZCAN
When I select the project mixed, it says that it should be limited in the warning section. Since I didn't see any errors in the report, I continued.
