Ground values are 0 after calculation on a continuous basis.
MevlutKAVAF
I have a B+3 FLOOR project. I used foundation all the time. I made changes to the basic dimensions and had it recalculated. After doing the analysis, I did not encounter any problems in the elective report part... When I check the foundation in the Menu > Reinforced Concrete > Continuous Foundation, MAX SOIL STRESS VALUES ARE 'ZERO' What can I do to fix it? ( BEFORE THE ANALYSIS, ALL GROUND G. VALUES APPEAR AND WERE NOT ZERO... )
Re: GROUND VALUES ARE CONTINUOUSLY 0 AFTER THE CALCULATION Hello If you add your project, we will help. Unver ÖZCAN
Continuous foundation joint points may not coincide on the columns, continuous foundations may be joining at idle, foundation piece may be left under the column object. Examine continuous foundation-column intersections.
I faced the same problem, as Hakan said, if you draw attention to the knot points, there will be no problem.
Examples of continuous basic correct and inaccurate data entries: Example1: Example2: Note: The ground entry showing zero is a situation that emerged in version 7. If you add your project, we can check if there is a problem with 8.
