salihaesen.52
I am attaching my project below. I'm getting a negative ground safety report, can you check?
Log in or register now.
The live load value on the beams should be given in m2 The program automatically multiplies the beam width."unver":16znzpee" said:Hello My Suggestions --Soil bearing capacity qt 1.55 t/m2 is entered, this value is incorrect. Check from the ground report. Moving loads are too high, lift at the 4th floor and multiply by the beam width at other floors (0.200*.6=0.12 t/m) --Add the ladder to the modeling, --As your structure is hollow block, the item 4.3.4.6 does not provide for overturning, it is difficult to provide. Unver ÖZCAN
