Ground safety negative
Re: GROUND SAFETY NEGATIVE I think you made a data entry error. Your ground safety stress will be 19 t/m2, not 1.9. It can't be 1.9.
Re: FLOOR SAFETY NEGATIVE Also, do not make cantilever beams from beams. It is not correct to make a beam that continues in an S shape and gets stuck in (or comes out of) the beam.
Re: FLOOR SAFETY NEGATIVE thanks bro, overlooked ground tension :d.......by the way, can you tell me which beams you said for?
