Ground safety negative error
statikçim
Hi, the basic type in my project is raft. Since 2 sides are adjacent, I cannot amplify 2 sides and the adjacent sides unfortunately go in diameter. too many indentations. No matter how many arrangements I make about the foundation in my project, I cannot fix the ground safety error. Methods I tried: -I increased the foundation height and reinforcement (for example, I even tried to subtract the foundation height from 90 cm to 150 cm) -I reduced the beam loads in the places where I entered too much -I played with the knot points of the curtains, but it still did not improve. Could you please review the project and help?
Hello there. I did not examine the project, but increasing the thickness of the foundation does not reduce the load on the ground, on the contrary, as the thickness increases, the building load increases, so it becomes even more below the ground safety. It is necessary to increase the foundation area, reduce the loads or increase the ground safety.
"puncover":awtqb3yt" said:
Hi. I haven't reviewed the project, but increasing the thickness of the foundation does not reduce the load on the ground, on the contrary, as the thickness increases, the building load increases, so it becomes even more below the ground safety. .
I did what you said, so I reduced the load and increased the area, but there was no change, but I don't think increasing the thickness of the foundation will increase the load.
"staticcim":2cchzpgf" said:
"puncover":2cchzpgf" said:
Hi. I did not examine the project, but increasing the thickness of the foundation does not reduce the load on the ground, on the contrary, as the thickness increases, the building load increases, so it becomes even more below the ground safety. It is necessary to increase the foundation area, reduce the loads or increase the ground safety. I increased it, no change. But I think increasing the thickness of the foundation does not increase the load
Increasing the depth of the foundation will not benefit you, on the contrary, as your friend said, it will be against you. You can try to solve the foundation as a rafter raft.
