I think what my brother NYILMAZ said is the most important thing. it is rather a matter of existing structure evaluation. The additional floor is created according to the new regulations. this is standard project process. on the other hand, the condition of the lower floors is subjected to performance analysis with the new state of the building. In the 7th chapter of tdy2007, it is clear how the core drills etc. will be. The assessment should ensure a) immediate use under design earthquake and b) life safety performance under severe earthquake impact for such buildings. If any of these conditions are not fulfilled, a reinforcement decision is made. If the cost of retrofit + new part to be built corresponds to 30-40% of the cost of rebuilding, a demolition decision can also be made. My suggestion as a working system; 1-Build the current state carrier system of the building. (do the core/cover stripping etc. detail works as specified in the regulation (it is best to work at the intermediate level)) 2-Enter the determined reinforcement diameter/piece/range values and concrete values into the program. and fix/lock reinforcements. beam reinforcement is the reinforcement obtained from 1.4g+1.6q loading. The stirrup spacing is determined by on-site measurement. 3- Be sure to save and store this data separately. this data should remain intact as long as there are no new detections. Create the system to which the upper floor is added with 4-save as. do the analysis. Do not forget to define a new concrete class and reinforcement class for the upper floor. Make a new structure design according to tdy2007. fix the reinforcements of this floor as well. Create a new file to investigate CG performance with 5-save as. Mark the relevant places as stated in the performance analysis preliminary form of the program. (LIFE SAFETY FOR EARTHQUAKE WITH A 2% probability of exceeding in 50 years) 5-save as and create a new file to investigate the HK performance. As indicated in the performance analysis preliminary form of the program, mark the relevant places. (IMMEDIATE USE FOR EARTHQUAKE WITH 10% EXCESSION IN 50 YEARS) one of the following two results a-building provided both performance levels: get well soon. the job ends here. report. Prepare the drawing of the upper floor. b-building did not provide at least one of both performance levels. then empowerment...+over-the-top projects... maybe I've extended it until I get it. My aim is to make a way for friends who come across. or if we have a deficiency, someone should complete it. As for ground safety. There is no recommendation in the regulation for fundamentals in performance analysis. If reinforcement is made, the foundations are reinforced accordingly. If you continue on the road without reinforcement, if there is not a very different stress situation, I say don't care about small violations.. regards...
