Dear İdecad Management; Although there is an error in the soil safety stress in continuous foundations in the attached file, the stresses do not exceed the safety stress in the soil stresses of the continuous foundations in the calculation section. You mentioned negative ground stresses in the previous topic, but I have to make a curtain on the foundation beams due to the level difference. Frankly, I don't quite understand why there is a negative tension due to the curtain and why it gives this error in some but not all fundamentals... I would appreciate it if you could examine the file and help. (Note: Steel roof trusses will sit on top of the columns and a point load of 10 tons on the side columns where the truss will sit and 20 tons on the middle columns is defined.)
