Hello everyone, I wish you a good work. 1) The effects of the rotations of the columns and especially the wall foundations on the soils in the C and D groups defined in Chapter 6, Table 6.1, on the calculation of the load-bearing system should be taken into account with appropriate idealization methods. (2.2.1.5) -According to this article in the regulation, structure-foundation interaction should be done together in C and D group soils, that is, some of the rotations and collapses in the foundation, foundation damping, and these are taken into account. a situation may occur (at the points we have overlooked) Is there a different situation related to this? 2) While calculating the ground safety stress, is there a chance to adjust according to the negative situation when calculating the G+Q, G+Q+E loads in the program? because in some cases, the earthquake situation can be less than normal loading. 3)6.3.2.1. Soil safety stress defined according to static loads and horizontal and axial safe bearing load of pile in pile foundations can be increased by maximum 50% in case of earthquake. It is always possible to increase by 50% in the program, regardless of the floor group. Are there any different situations related to this? Thank you for the comments of valuable friends who have opinions, good work OMER FARUK ÇAKIL
