"gkeskin":299wammg" said:I tried the basement floor curtains without flooding, but it still gives the same error, what can I do?
"Levent Özpak":299wammg" said:In your project, there is B1 irregularity on the ground floor as well. ... The effective cutting area of the wall on the ground floor is very small compared to the effective cutting area of the wall on the 1st floor. If you think that the wall effective shearing area on the ground floor is larger, you can also intervene in the wall effective shearing areas from Akx, Aky columns as in the curtains.
Ünver, the project is not mine. Sorry"unver":3e3b6bha" said:Mr proisa My advice to you: - Why did you make the beams with a maximum clear span of 5.30 m (3 different places) in two different sizes? (half K37 25/45 and half K38 35/32) SUCH HOW TO PASS THE PROJECT FROM YAPI AUDIT? DOING A PROJECT IS NOT WRITING DATA TO THE PROGRAM. YOUR BUILDING MAY BE DAMAGED WITHOUT EARTHQUAKE BUT THERE IS A HIGH POSSIBILITY TO DOWNLOAD AT THE TIME OF EARTHQUAKE. Please read all the suggestions made in this forum.) Ünver ÖZCAN Let's not make these mistakes in projects. (the program prevents some of the mistakes, but let's be careful.)
Please delete this project. Start from scratch. Erase everything about your old project from your memory as well. Why did you make curtains all over the basement floor. Is the basement a complete water tank or something? Why didn't you use beams? Also, why don't you extend your beams in the consoles. If you are making a ribbed floor, you have the right to have beams from everywhere. Why don't you connect them with columns and beams properly? You have 3 curtain columns on the floors and they have almost no contribution to the system. In the 1st degree earthquake zone, you tried to cross 8 meters of misalignment with a 25/45 beam. Please delete this project. Delete everything related to your old project from your memory as well. Start over from scratch."gkeskin":2j4844fx" said:my project is a 3-storey project without basement? In the reports, it gives an error that ground floor = weak floor, ni<0.60, increase system rigidity, but there are plenty of curtains in my system, what can I do? file is available in the attached link .
