mehmet2015
HOW CAN I ENTER THE DEFINITIONS OF ALL THE DEFINITIONS (COLUMN BEAM FLOORING ETC.) TO BE MADE ON THE GROUND FLOOR IN CREATING THE BASEMENT? I WANTED TO ADD MY FILE BUT I CAN'T UPLOAD DUE TO THE LARGE SIZE.
"mehmet2015":1903rry9" said:HOW CAN I ENTER THE BASEMENT IN CREATING THE DEFINITIONS (COLUMN BEAM FLOORING ETC.) TO BE MADE ON THE GROUND FLOOR? will be:You do not have permission to view link Log in or register now.
Did you check the link I gave you exactly? You must define it as a separate floor."mehmet2015":2d78bhjy" said:I MADE CURTAIN ENTRANCE TO SU BASMAN LEVEL BUT I CAN'T ENTRY TO THE FLOOR, FOR EXAMPLE, IT GIVES A FAULT FLOOR LEVEL WARNING WHEN I ENTER -280 AS A LEATHER. HOW DO I DEFINE FLOORING BECAUSE THERE IS NO BEAM IN THE LEVEL?
