Hello, good work, when I enter the value of the ground dominance period to the system from the Analysis settings / TDY options, there is no change in the analysis results. I'm talking about the ground dominance period Z3 ground. Since it is a value between 0.15-0.6, if the construction period is in this range in the regulation, is the analysis results not affected because it already takes S(T)=2.5? Or should I enter the ground dominance period value in another way? ? I hope I was able to explain. good work best regards
