Grid and border settings program closes
Re: grid and border settings program is closing
"mkrts88":1p9jn1ad" said:
good forums when you say grid and border settings with version 10.05 installed, it suddenly closes, good work
Hello, this is the right click menu The situation will be fixed in the next version.You can use the General Settings, Grid Borders tab to make changes to the grid and border settings.
Re: grid and border settings, the program is closing at least until the problem is fixed, can you remove this option from the right menu? I forget, I click from time to time
"mkrts88":d49zg227" said:
at least until the problem is fixed, if you remove this option from the right menu, I forget about it, I click it from time to time
You will also be able to use it from the right-click menu.
