Hello Mr. Ozan; - Ladder is correct fixation, edit the support conditions or remove the ladder from the model. - Since your purlins are analyzed as one piece, they are more than 12 m and it will cause you problems in the support areas, we recommend you to use the divide by all intersections command. The edited version of your model is attached. Good work.
