Hello, I have a project glass porch, but I cannot connect the tension profile of the porch to the reinforced concrete column and steel beam as a movable support. Can you help me ?
Hello there; You can use cross-end join. As you can see in your image inside the reinforced concrete side, a connection was created on the metal facade cladding. Therefore, you can apply the same combination again. Good work.
