Hello friends, I need to solve this problem urgently. Static analysis gives a stapling error in the project I do, what could be the cause. how can i solve this problem it is urgent!!! Columns s06-s07-s09 have stapling
I just downloaded it, it would be great if you could check it out. We had a problem because the architecture could not be changed. Colonization can be done again.
Hello, my suggestion: --make your foundation thickness 55 cm (You get rid of stapling.) Also: --enter the stair loads --check the wall loads --center the beams to the columns --make sure to fix the errors in the columns (B) Take it easy Ünver ÖZCAN
Thank you. the stapling problem is solved in this way, but I tried to fix (B) but it didn't work. I had a problem because many changes could not be made in the architecture. Is there anything you can suggest for this? Or a column you can suggest?
