Getting a drawing in a Scaffold Macro
This is one of my problems too. I think you can't get the side view of the pier as a drawing. Drawings can be taken in 3 different ways: isometric view, plan view and facade view. Hopefully this will be fixed in future updates.
Hello there; The pier view is formed in the x and y directions. If the side view means the view of the scaffolding from another side of the building in isometric view, the angle or direction is not important. Municipalities require a scaffolding drawing located along the entire perimeter of the building, and this detail is created in plan and isometric view. However, if you inform us about the details other than the above-mentioned drawings or the different formats of these details, the required work will be done. Good work.
I actually relate to this; I was going to suggest right click / create vector drawing command in 3D screen. But I tried: I saw that the scaffolding elements only drew the stairs, the walkway, and strangely, the ends of the other elements. I give up. Ms. Nurgul, could you please check it out?
