Geotechnical report vt value
recepekmekci
Good afternoon, I could not find the vt value in the form below. Do I have to calculate this value manually? Another point I want to ask is is this for the x direction or for the y direction?
"recepekmekci":2h7f557f" said:
Good afternoon, I could not find the vt value in the form below in the report, do I have to calculate this value manually? Another point I would like to ask is is this for the x direction or the y direction?
There are necessary explanations in the following title .
Hello there; The Vt value is calculated for the X and Y directions according to the Equivalent earthquake load method or the Dynamic analysis method and is printed as a table on the first page of the Dynamic analysis reports. The Vt value is used for the slip control of the building, so since the floor area of the building will not change for the X or Y direction, it is sufficient to use the larger of these values and check for one direction. If you are to consider the passive soil thrust acting on the basement perimeter walls due to the buried basement as the force resisting shear, then you can calculate separately for the X and Y directions. Best regards.
