Hello, Floor Height; 430 cm - When I enter the dimensions of the Basin Curtain as 25 * 80 cm, when I check the Geometry, the Curtain also gives 1/16 error.
Hello, If your curtain is a sub-basement curtain, if you select the option "Basement / curtain that does not continue on all floors" from the curtain settings, 1/6 dimension control will not be performed on these elements. Good work
Hello Mr. Emrah, Thank you for your help. I would like to consult you on one more matter. When I draw a U-type curtain with a height of 600 cm, it gives an error of 1/16 and the thickness of the curtain reaches the dimensions we do not want. What kind of drawing should I draw in order to solve it at 1/20? Good work
