Geometry checkbox
myusufb
Hello, as can be seen in the picture, when I check the geometry, the box opens somewhere above the screen borders and does not move anywhere. I uninstalled the program, reinstalled it, changed the screen settings and it still did not work.
"myusufb":vjggbsr9" said:
Hi, as you can see in the picture, when I check the geometry, the box opens somewhere above the screen borders and does not move anywhere. I uninstalled the program, reinstalled it, changed the display settings and it still didn't work.. How can I solve this problem?[/quote ] 1. Exit the program 2. While running the program, hold down the left shift + ctrl keys at the same time 3. When the message Registry settings cleared, release the keys you held down 4. Click the OK button 4. Check the problem, is it solved?
