Fundamental stress is 0
"civilman":11lj6xc8" said:
good afternoon.Soil tension is 0 in the attached project. What is the solution and reason?
Hello, define the ST2 continuous foundation by clicking on the columns S02 and S03 as indicated in the picture. Edit the continuous foundation misalignment to include P003 as at least 40cm. This adjustment does not need to be made in version 8. Note: -The eccentricity of the ST7 and ST8 continuous bases has not been entered to include P001 and P002. Good work.
"Levent Özpak":1zdfymzl" said:
"civilman":1zdfymzl" said:
have a nice day. In the attached project, the soil stress is 0. What is the solution and reason?
Hello, define the ST2 continuous basis by clicking the columns S02 and S03 as indicated in the picture. At least 40cm including the continuous foundation misalignment P003. edit as defined. This edit does not need to be made in version 8. Note: -The eccentricity of the ST7 and ST8 continuous bases has not been entered to include P001 and P002. Good work
Levent Bey, when I do it, this time the other basics are strangely failing. When you enlarge the size to correct it, the number of errors increases basically. Did you somehow save it? or what should i do
"civilman":k443db4j" said:
When I do it, Mr. Levent, the other basics give a strange error this time. When you enlarge the size to correct it, the number of errors increases, basically. Did you ever save it somehow? Or what should I do, regards[/quote ] Hello, There are problems caused by stirrup insufficiencies in permanent foundations. Problems can be solved by choosing larger stirrup diameters from the reinforcement selection dialog. Good work
"Levent Özpak":2u8c3lq2" said:
"civilman":2u8c3lq2" said:
When I do it, Mr. Levent, this time the other basics are giving a strange error. When you enlarge the size to correct it, the number of errors increases basically. Did you somehow save it? Or what should I do, respects
Hello, There are always problems arising from the insufficiencies of stirrups in the foundations. Problems can be solved by selecting larger stirrup diameters from the reinforcement selection dialog. Good work
Thank you very much, Mr. Levent. Good luck with
