Fundamental Error
Murat Kanıcı
Hello, I would like to design a raft foundation without a structure to be used as a stage as I have attached. However, the foundation does not save, although there is no significant load on it. Where could the problem come from? Best regards.
No columns are defined in the system, so slab thickness cannot pass this test as it is also tested with openings in the regulation. If your goal in doing something like this is to place reinforcements and get a drawing, just place three or five columns and it's done. Why do you feel the need to give this an engineering account? It falls under the class of simple structures. If this is a scene, I think nothing else is needed.
Hello, -You entered the bed coefficient of 10000 t/m3. You may have made a unit error, please check. -As Nedim Bey stated, since the column is not defined in the system, there is a problem with the basic thickness control. -There were problems with some of your programmatic settings in your model, we fixed your settings, but you should review your analysis settings. (Earthquake zone etc.) - Solve the model with the superstructure interactively, when it is solved without interaction, there is a problem in the model. We will work on this issue and make the necessary arrangements.
