Friends, general mistakes in the project and what I need to do are right.
Re: Friends, general mistakes in the project and what I need to do ha Hello. --Update the version, --Fix the errors in the geometry control, --Drop the outer beams if they come to the walls, --Support the ladder and solve it together with the building Ünver ÖZCAN
Re: Friends, general mistakes in the project and what I need to do ha - Wall loads 2.5 m Aerated concrete wall selected (you need to be 100% sure that it will be done in practice) -Remove typical beam and slab thread continuity warnings in geometry controls -Cross ribs on slabs straighten your teeth. -It is useful to extend the p06 curtain. You can remove the beam stud. It is useful to connect the beams to the column - Analyze the structure as a semi-rigid diaphragm. -Include the ladder in the system -U-type curtain left empty inside the bucket (not connected with beams) A different design can be considered.
