French balcony definition on beams
ATK
Mr.s; In order to make a french balcony in some places in my project, I throw 20 cm in a certain part of the beams (50 cm long from the place that corresponds to the middle of the 4m beam). To do this, when I define a slab edge and put a slab inside, it divides the beams and when these divided beams are copied to an upper floor, they appear as overlapping objects. Also, I want to show that part of the beam as 20 cm overflowing, not as a slab, because 50*30 I don't want 10-12 cm thick slabs from pillow beam sizes. Also, I want to go to a solution by using a single foundation on two columns that are very close to each other and in diagonal veins. ?[/one]
Splitting the beams shouldn't be a problem, if you add your project we'll review it. If you want to make the 20 cm French balconies you mentioned look like stones, it may be a more accurate and practical method to define them as external loads instead of modeling them as floors. Currently, there is no solution to more than one column by defining a single foundation in the program, you can get the analysis effects correctly by modeling the raft (with slab edges) in the single foundation size.
