Freezing Problem while receiving ideCAD Report
rfkiran
Hello, I drew a sample project in the program and I did a lot of analysis. After performing these analyzes, the program freezes for a while while receiving reports. While trying to get a report, it has not been processed for a while. What is the reason of this? Is there a situation that can clean the program files and make it old fast? Thank you in advance. Good work.
Re: About ideCad Freezing Problem. Help
"rfkiran":3a3pa3bz" said:
Hi, I drew a sample project in the program and I did a lot of analysis. After doing these analyzes, the program freezes for a while while receiving the report. It does not work for a while while trying to get the report. What is the reason? Is there a situation that can clean the program files and restore them to their old speed? Thank you in advance. Good work.
Hello, The issue has nothing to do with the number of analysis or cleaning the program files. If the problem occurs in every project, Bursa Call our office, let's look into the matter by connecting remotely.
