Freezing during analysis
sara
hello, after creating the building system, it comes to a certain level during the analysis and freezes, the analysis is not completed, I would appreciate if you could help
I tried on 2 different computers, both of them froze in the same place, what do you think is causing the problem? Did you do anything? One of the computers has 4gb ram and the other has 6gb ram, could they be insufficient?
I did not make any changes, I do not think that there will be a shortage of ram because the data is small, can you save it as an old version and try it in 7 versions.
The number of mods is insufficient and the second order value is too high Mr. Güray, thank you very much for your help, I solved the problem by turning off the superstructure interactive solution from the analysis settings, but this time, the number of modes is insufficient in dynamic analysis and the second order value on floors 1,2 increase the system rigidity is very high problems have occurred i tried a lot of things but not solved what can i do about this when i increase the number of mods it still freezes i would be very happy if you can help me. Thanks in advance
I did the analysis as you posted, without touching anything (just entering the ground class). The analysis is complete and I haven't encountered a problem.
What were the ground values you entered, it's the first time I encounter such problems and I don't know why, there is no problem in my other projects, I just experience this event in this project, I drew it from the beginning and nothing changed.
I think I chose Z3. I chose something at random. And I don't think that's something that would create the problem you're describing.
Thank you for your attention, I don't think so, but I had to think about every option. Is it because of my analysis settings, I don't know if there is a problem with my pc or bnm program, I need to find a solution urgently.
When I download the file I sent and do analysis, I encounter those problems. I can't send the new file anyway, because I compressed 10 mb, it fell to 6, but I can't send it again. There is a 4mb limit. You have the same problem with the old file and the new file, which has no problem in the analysis. I'm using ide8. I tried it on 2 different PCs. The same problems were encountered on both of them. I don't know if the software in that one might be defective.
Thanks for your help and interest, I applied to technical support, I hope they can find a solution now. Good work to everyone.
The causes of the errors in the project were determined and resolved. I would like to thank the technical support team for their help.
