freeze while calculating
erdoğanaşık
It freezes while calculating in the attached file. Because the file size is large, the 3rd normal floor has been deleted. After the file is downloaded, copying can be made from the lower floor.
You did not choose the vertical reinforcement diameter for the wall end area, there is a panel-column junction error in the basement floor. I copied the 4th floor to 3, fixed the errors and solved the project without any problems.
"erdoğanaşık":91w3unka" said:
freeze occurs while calculating in the attached file. Because the file size is large, the 3rd normal floor was deleted. After the file is downloaded, copying can be made from the lower floor. Also; *P2-P3 panels and K34 beams in the 1st basement floor seem not to be connected to the S2 column.
