Foundation stresses in the report
Acemii
In the report, the stress and shear moment forces that will occur at the foundation always seem to be zero.
Re: foundation problem While drawing a continuous foundation, the column is not combined with the nodes. If you draw the continuous foundation by joining the column nodes, the problem will be solved.
"Novice":2eu6iovh" said:
the stress and shear moment forces that will occur in the foundation always seem zero in the report, what can I do to fix this problem
Joint points of TK07-TK26 continuous foundations S07 column , the nodes of the TK11-TK32 continuous foundations do not connect to the S10 column.
Re: In the report, the foundation stresses are zero, help hello friends, the ground stress is zero, I checked the nodal points one by one in the data I made, but it is still zero, can anyone share it?
