B bartayd New Member May 29, 2016 #1 When we get the mold plan drawing, when the stretch command is used, the axis circle is shifted, but the text remains???
N NYILMAZ New Member May 29, 2016 #2 The stretch (move joint point) command is related to the joint points of the objects. However, there is no knot in the article. If you use the move command instead. then you can move the end of the axis line with the nodal stone.
