Floors are not visible in sap2000
YilmazKeles
Hello, I transferred the project I prepared from İdecad v(10.03) to sap2000 (v20). What could be the reason why the building weights are different and the floors are not visible in sap2000?
Re: Data problem when transferring to sap2000
"Ismail Hakki Feeds":2pjqg6gf" said:
"YilmazKeles":2pjqg6gf" said:
Hi, Idecad v(10.03) the project I prepared sap2000 (v20) ' I transferred it. What could be the reason why the building weights are different and the tiles are not visible in sap2000, what could be the reason?
Add the ideCAD file with ide10 extension that you transferred to Sap2000. If the ideCAD solution is not a semi-rigid solution, naturally, placards are not transferred to sap2000.
Re: Data problem when transferring to sap2000 Thank you for your answer Mr. Besler, when I solve the model as a semi-rigid diaphragm in idecad and transfer it to sap2000, the floor appears. Why does it not appear on the floor when we transfer it when we dissolve it as a rigid diaphragm?
Re: Data problem when transferring to sap2000 Because when you do not create a semi-rigid model, you want the blades to behave as a rigid diaphragm. In this case, the floor planes are modeled as rigid diaphragms by transferring the load from the plates to the beams.
