Flooring Wall load
ower
Are the walls taken from the architecture transferred to the flooring automatically as a load? Can you take a look at the short story of my mistakes in the project that I sent in the attachment?
"ower":24jq966z" said:
Are the walls taken from the architecture transferred to the floor automatically as a load. Can you take a look at my mistakes in the attached project?
Hello, The walls drawn in the architectural project are transferred to the slab floors automatically. For example, columns S1-S11-S13 do not divide walls.
Mr. ower MY SUGGESTIONS: -- Enter the B039 beam, on which the staircase is supported, as the mezzanine beam at the stairwell level, -- If you define the support conditions with Determine the stair support conditions and solve the building as a semi-rigid diaphragm, you will automatically give the stair loads. -- If you haven't used version 7 before, read the articles asked and answered for version 7. A REQUEST FROM IdeCAD: CAN WE SEE WALL LOADS IN ARCHITECTURE AS LINEAR LOAD ON THE MOLD PLAN? (There is hesitation because it cannot be seen.) Take it easy, Ünver ÖZCAN
