First of all, thank you very much for your interest and suggestions. There are gradual spaces inside the sculpture (restaurant, exhibition halls, etc.). I also thought of the raft base thickness just like you did. In other words, the effective height of the statue is approximately 30-35 meters. If the floor height is 3 meters in normal buildings, the raft foundation is made with a thickness of 100 cm in a 10-storey, that is, 30-meter structure. Of course it's an approach and it seems logical to me for now. The weight of the outer shell of the statue was stated as approximately 750 t. At the same time, if we take into account the system's own weight and live loads, and with a safety margin, it will have a weight of around 2500-3000 t. The design issue here is that this load can be axially distributed to the columns with a margin of safety, but theoretical approximations are required for moments and shear forces. For example, I divide the sculpture into 4-5 parts along its height, and build a calculation model with the lumped masses in these parts (mdof systems in building dynamics books) and try to find the internal forces. But my time is very limited. You need to think more simply. It tells me to rely on the dimensions of the columns (linear and non-linear shear and moment carrying capacities) and do a complete stirrup tightening, but the economy must also be taken into account. Also, I don't think cassette flooring or beamless flooring can be done. If combining the continuous and rail foundation system in this way is wrong in terms of the mathematical model, what should be done considering the cost?
