flooring reinforcement
Hi, In some tile edge panel intersections in your project, the nodal points do not occur at the intersection point. These connections and slab edge panel intersections are arranged as in the ground floor in the attached project. The ground floor was copied to the regular floors, including the 9th floor. The panels and flooring on the 9th floor with a height of 160 cm were entered as a separate floor. It is useful to check the slab size and load information in the project.
Good work
