Flooring Problem
ecspa1
Good night, I had a question while defining the tile, when I select the tile and move the mouse to the area, there are overflows (at the column-beam junction areas) but when I turn the mouse right and left before leaving the tile completely, the situation changes.
Hi, If your tile is protruding beyond the enclosed space you want to place, there may be a problem with the enclosed space created. If you add an example where you're having trouble, we can give you a more precise answer. Good work
Hi, to the right of P04, the beams connected to the panel were holding different joint points... I have attached the project where I placed the slab to the message. Good work...
