Flooring Design at Different Levels
dago46
Hello, due to the floor height difference, the landing floor level of the basement stairs is 53 cm above the floor slab. I set the elevation of the landing floor and the upper level of the beams to work together to 53 cm, but when I analyze it, I see that no reinforcement is placed on the landing floor. How can I fix this situation? I would be glad if you help.
hello, I can't find the error that the network cannot be created for the tiles in the project I created. Do you have a chance to check if there are some different errors that I get? I wanted to add the project but it didn't add because its size is 3.15 MB. I can mail you if you want.
