floor
The trim algorithm has changed in the connection of K1 and K3 beams with the panel. If the beam offsets are arranged as 20 cm, the slab boundaries are formed correctly. Good work
It gives the same trouble at the corner joint, how can we fix it or if we create the flooring in this way, will we encounter a problem
