Hello, since there is a 150x140 cm skylight in my construction, I need to create a tear in that part. I wonder if it is a healthier analysis to create it with the floor space command or to turn that part with beams and create a frame?
Hello, in rib and cassette floors, floor space cannot be opened to divide the beams, as you can see in the plan, even if you open a gap, rib beams are visible. In such cases, define it by dividing the sub-joists and the floor.
Electric and machine shafts are visible under the skylight, considering these, I think it would be more appropriate if you define a beam from the P53 curtain to the K017 beam and connect the K11 and K13 beams to this beam.
It's not like you do. In this case, the intermediate rib is directly inserted into another beam, which is a cantilever chain inside. If it is, it is better than the picture attached. It is also supported on the beam stepping on the curtain.
