FLOOR REINFORCEMENT INSUFFICIENCY
DEXTER
Hello, I'm planning to buy an Ide so I'm doing some testing on the demo. I tried an example of a structure with many stud beams. Although there are no errors in the beams, there are errors in the floors. Insufficient reinforcement faults. However, after fixing them, errors start to occur in other tiles. And even though I use absurdly dense reinforcement, I can't fix some errors. I would be very grateful if you could check the model and share a comment. Thanks.
In your added project: Cancel all slab reinforcement fixings from the Reinforced Concrete dialog. F9 Analyze. Insufficient reinforcement message does not occur on the floors. The corrected version of your project is attached...
