MustafaAkın20
Hello, I would have two questions and a note; 1- For the design of reinforcement without pile in floors, can't we mark it as reinforcement without piles, as in beams? It is difficult to select the reinforcements one by one and mark the bottom reinforcement as flat
. First, I make a floor with a sub-flat. I say get the settings from the object and create other tiles, but the reinforcements still remain in the pleated selection, so I couldn't figure it out. 2- In continuous foundation expansions, the representations of the upper and lower reinforcements in the foundation section are not as in the beams. Namely; For example, there is 4Ø16+3Ø14 reinforcement at the top. It is written like this in the drawings, but is it possible to show these reinforcements with an arrow, as in the beams, or is there something I haven't discovered? In addition, there is no "additional" expression for additional equipment. It seems like it would be good to integrate the beam drawing module into the foundation as well. Finally, the situation regarding the capacity ratio, which I said before in my messages. You said that the answer will be given in our notes and in the form of a warning, but it would be great if you improve this as soon as possible. It goes through the project mostly with these controls
and it seems essential to optimize it directly, not as a warning, and equip it so that the capacity ratios are <1. I wish you good work...
