FLOOR PROBLEM
kasky
In the attached project, some slabs are not calculated when I do a slab analysis. When I enter the slab elevations as -1, it calculates, but I do not understand the problem. I would appreciate it if you could help me
"kasky" said:
In the attached project, some slabs are not calculated when I do a slab analysis. When I enter the slab elevations as -1, it calculates, but I do not understand the problem. While entering the floors, the following conditions should be considered. Ground floor Beam K28 and the lower floor edge of the slab BD01 are not connected to the beam K30 at the nodal point. K36 beam does not connect to S19 column. K279 and k49 beams should be connected to the BAP3 panel at the joint point. The bottom floor edges of the BD06 and BD04 floors are connected and the joint point formed on the beam is not in the same coordinate. The junction of the slab edge of the BD03 slab and the joint point formed in the K61 beam are not in the same coordinate. Bodrum Floor There is an inconsistency between floor beam and panel levels in the basement. Some incompatibilities detected; -D10 and D12 floor elevations are wrong. -The right end of the K87 and K92 beams is higher than the BAP 02 curtain, and the BAP02 panel in the upper left corner of the D169 floor is not at the same floor level. -The elevation of the D173 slab is not compatible with the BAP08 panel that forms the left edge of the slab. In the project, the link of which is given below, the problems stated on the ground floor were corrected and the floors were placed again. The slab analysis is done correctly. Basement floor data was not interfered with.
Good work
if you look at this again some tiles are not calculated and in 3d frame some tiles are full with crease edge but some are blank I wonder is it my mistake
"kasky":2fjqg9lg" said:
http://hotfile.com/dl/149118916/43ff3a1/DEME.cde.html if you look at this again, some tiles are not calculated and in 3d frame some tiles are full of creases but some look empty. I have a mistake
Basement floor determinations -The point where the K16 beam connects to the BAP22 and BAP21 curtains and the joint point formed on the walls are not in the same coordinate.The point where the K29 beam connects to the BAP1 curtain and the joint formed on the curtain are not in the same coordinate -The upper level of the K35-K40 beams are connected Not compatible with BAP02 -The elevation of the BAP08 curtain on the left side of the D08 slab is not compatible with the slab. Two parts of the BAP04 panel are entered unnecessarily. The above-mentioned cases have been corrected in the project linked below and the slabs at the same level are analyzed together.
