Hello , unable to create tile mesh. And column beam intersection does not save. I am waiting for your suggestions and help at the minimum level. Bodrum car park
Re: slab mesh does not form, column cross section Hello, connect the K52 beam at the nodal point of the S11 column. Laying meshing problem will be solved. (The sample project is attached.) For the column beam connection shear safety problem and possible solutions, you can review TBDY 2018 article 7.5 and the link below. (For example, if the width of the K52 beam is made 50 cm instead of 40, the Joint shear safety problem in the S11 column is resolved.)
Note: We recommend that you analyze by reducing the widths of slab and curtain finite elements. (For example 25 cm) For continuous resolution of K36-35 beams with K34-33-32-31-30 beams, changing the view directions of the Modify/Beam Foundation/Determine Object Orientation command In the General Reinforced Concrete parameters dialog, click on the line "Continuously accept beams with small angle difference". It would be appropriate to enter the angle value of 15 degrees.
