FLOOR DEPLACE ERROR
ibrahim.ozuag
1-2-3 WITH FRIENDS GROUND FLOOR. FLOORS ARE SIMILAR FLOORS. SO THE UPLOADS ARE EXACTLY THE SAME. BUT THE FRONT BALCONY ON THE GROUND FLOOR DB02 GIVES AN DIFFERENCE. I CAN'T UNDERSTAND THIS ERROR WHY IT IS ONLY ON THE GROUND FLOOR, WHEN IT IS EXACTLY THE SAME WITH OTHER FLOORS.
"ibrahim.ozuag":2laacl9y" said:
FRIENDS GROUND FLOOR AND 1-2-3 FLOORS ARE SIMILAR, SO THE LOADING IS EXACTLY THE SAME. BUT ON THE GROUND FLOOR, THE FRONT BALCONY DB02 GIVES IGNITION FAULT. I CAN'T UNDERSTAND THIS ERROR ON THE GROUND FLOOR.
Hello, The corrected version of your project is attached. "This beam carries the console floor" option was selected in the Static / Reinforced Concrete settings of the Ground Floor K8 beam.
"ibrahim.ozuag":wpx3zj7o" said:
Thank you very much. Can you explain how you solved the slab mesh problem. ?
In the previous version of your project, if you examine the tiles in the 3D frame, the meshes were formed incorrectly. The tile edge line remaining inside the D4 tile was visible on the beam I just moved the node of the line of the tile edge.
