Hello. In the beam adjacent to the floor that gives a floor error: (longer beam K19) beam settings"This beam is living cantilever flooring" activate Ünver ÖZCAN
On the ground floor, unlike the other floors, console floors are defined -25 cm low. If you didn't do it on purpose, you correct the data entry. If there is no level difference, the console floors will be continuous with the interior floors and you will not need to activate the "This beam lives the console floor" option.
Thank you very much, Mr. Ünver and Mr. Hakan, the level difference will be obligatory, I adjusted the K19 beam, the problem was fixed, thank you again, good work.
