o-ren ishii
how can i solve this problem? thanks in advance
while connected to the internet when you run the program -There is a new version(7.015.).Do you want to install the latest version?- if you say yes to the question, you will be directed to the page where you can download the latest version. This version has been removed. For newer versions,"o-ren ishii":2xu61y8s" said:thank you so much when I read it, I realized my mistakes too. I'm a bit of a beginnerand I'm using idecad version 6, so I can't open the project you've fixed because of v7. how can we handle it
Rigid connections can be red or green... it is not a problem."sereze":evxm8rld" said:.... also the rigid connections at the nodes you fixed are red, not green. Is it a problem if it is red?
