Floor deflection error
Apokalips
Good day, in the attached project, can you give suggestions for me to solve the slab deflection problem in the basement floor D64 slab in the full rigid diaphragm solution?
Re: FLOOR DIFFERENCE ERROR Hello, it is seen that the rib teeth of D16, D64 and D13 floors have a very small angle difference between them. If the relevant floors are defined as continuous, the deflection problem in the D64 floor is solved. Good work
