Floor Analysis
Although the nodes are connected in the tile analysis, there are tiles that do not participate in the analysis. I couldn't figure out why. I am waiting for your help. Apart from that, I would be happy if you comment on the places you see missing.
"YEZulkadiroglu":3lykymo9" said:
There are tiles that do not participate in the analysis although the nodes are connected in the slab analysis. I could not figure out the reason. I need your help
Hello, on the 8th floor and other similar floors: 1. Defined above D01 and D022 The arc slab edges are not defined at the nodal point of the beam K52. K52 is defined from the middle, take both slab edges to the joint point of K52. 2. In the cantilever slabs defined at K04 and K07, the slab edge is placed without dividing the beams K04 and K07, respectively. correct the data. First delete the slabs D05, D06, D08, D11, then define the slab edges to divide the joists from K04 and K07. Then define the slabs again. 3. When you check the geometry, you will see that there is a short beam left to the right of K78. Delete that beam Do all of these operations on similar floors as well.
Hello, The borders of D01-02-05-06 tiles are formed incorrectly in the mezzanine and normal floors. Connect the slab edge of the D01 and D02 slab to the K52 beam at the joint. Redraw the left and right slab edges of the D05 and D06 slabs so that a joint is formed on the K04 and K07 joists. Good work
