serkansarp
Hello, There are a few points that we are curious about in the attached project, which is our first project. 1-) As seen in the picture, the ladder sits on the ribbed floor. The point we are wondering here is whether the calculation should be done by leaving the slab edge blank or it would be better if we place a beam around it as in the picture. In this case there are two studs very close to the middle beam, wouldn't it be better to avoid that? 2-) In this project, the upper level of the foundation is at -70 cm and the basement is at +50 cm. The column height is 280 cm from the basement and there is no basement curtain. In this case, how should or should the column and sub-basement beams be modeled in the distance between +50 and -70, that is, from the ground floor slab to the foundation? Thanks in advance for your time, Good work.
