FINISH PROJECT YADIM ACİLLL!!!
sinan556
Hello, my final homework is to design a 5-storey workplace, there is no basement, ground plus four normal floors. foundation is also the ground floor slab... it's only been a few days since I started using the program, so I'm a very newbie. I entered the data as far as I could tell from the visual training videos, but I don't know how accurate it is. I urgently need evaluation, comments and advice, I would be very happy if you could help.
Hello, In your project, the stair exit arm is not connected to the intermediate landing. When creating stairs, create the intermediate landing contour in parts as in the attached example. I suggest checking the -superstructure interactive solution- option in the Analysis Settings/Base Ground tab. I recommend placing the stair landing on the mezzanine beam. (between S04-S05 columns) Good work
