Greetings, I saw a few topics or questions on the subject. As the İdecad family, you prepared a pdf and over 400 friends downloaded it. My only thought is that the pdf is not descriptive enough. it shows us how to find the new lambda value by making a solution. My problem is that the lambda value is fixed at 0.66 in the program on these zf floors. But as can be understood from the regulation article above, we need to calculate a correct and new lambda. It says its ratio to 2 gives our new lambda value. But I don't know how the elastic spectral accelerations in dd_2 and dd_3 are calculated or whether it is clearly stated in the reports. Actually, you have explained how to find it, but I believe it will be very useful if you can show an example with a solution supported by visuals. I've talked about the subject with a few colleagues, many people are not sure what they are doing. I think it will be very useful for everyone. Thank you.
