Finding insufficient section in scaffold
mkrts88
In the building with 4 sides of scaffolding, only one section is given an insufficient warning, but how can I find that section (column) I can't find which scaffold it belongs to.
Hello there; When you receive an optional report, the first page lists which elements are insufficient. If you take the column name from here, find the name in the building tree - elements - steel columns section and select it, it will light up in a different color in the model. However, you cannot change the cross-section of only one column for scaffolding. Since the system is modular, a cross-section type is used in a pier. For this reason, you should arrange all sections on the scaffolding on that front. Good work.
However, you cannot change the cross section of only one column for scaffolding.
I am aware that there are only projects where we define 7-8 separate piers. Which pier has a problem, at least I want to see it, and also, is the problem in the beams? in the crosses? I've seen them too, thanks for your interest
