First of all, greetings to everyone... I have some questions and I will need support on a few issues... 1. As it is known, in case of negative opening moment in the beams as a result of calculation, the assembly reinforcements remain in the tension region of the beam. However, the program puts either the statically necessary pursantage or 2Q12 anchors for mounting reinforcements, which can be lower than the TS 500 minimum beam tension zone reinforcement ratio. If the tensile zone is at the bottom of the beam, this ratio is automatically controlled. It'd better be checked in the case of negative torque as well. 2. When we want to have nonlinear static analysis, why do we need to get the loading states from the linear analysis section of the structure tree. If the loading conditions are not defined in the linear analysis section, we cannot define the loading conditions for the nonlinear analysis. In nonlinear analysis logically, shouldn't load cases be defined as child-nodes in the structure tree? 3. I wanted to add non-linear analysis loadings to the combinations in the template project. Since the template project was empty, I first added G, Q, EX, and EY loads to the linear load cases. Then I added nonlinear G, Q, EX and EY loads to the system using these load cases. Then I added the nonlinear 1.4G + 1.6Q, G+Q+EX, G+Q-EX, G+Q+EY, G+Q-EY combinations to the combinations. I drew an example system on this template and solved it. However, the program defined the G, Q, EX and EY states that I added earlier to the Non-Linear loading cases for the second time... And it calculated twice during the analysis... Should we define the loading cases and combinations that are not automatically defined separately for each project... Thank you in advance...
